Air Duct Friction Loss: Pressure Drop Calculator & Chart
The major loss, or friction loss, in a circular duct in galvanized steel with turbulent flow can for imperial units be expressed
Δh = 0.109136 q1.9 / de5.02 (1)
Δh = friction or head loss (inches water gauge/100 ft of duct)
de = equivalent duct diameter (inches)
q = air volume flow - (cfm - cubic feet per minute)
For rectangular ducts the equivalent diameter must be calculated.
Air Ducts Friction Loss Calculator - Imperial Units
The head loss calculator below is based on formula (1) :
Head loss and air flow velocity for some common duct sizes and air flow volumes can be taken from the table below:
| Air Volume (cfm) | Head Loss (inches water gauge per 100 feet duct) | ||||||
| Air velocity (ft/min) | |||||||
| Duct Size (inches) | |||||||
| 4 | 5 | 6 | 8 | 10 | 12 | 16 | |
| 100 | 0.65 | 0.21 | 0.09 | 0.02 | 0.01 | ||
| 1146 | 733 | 509 | 286 | 183 | |||
| 200 | 0.8 | 0.32 | 0.08 | 0.02 | 0.01 | ||
| 1467 | 1019 | 573 | 367 | 255 | |||
| 400 | 1.19 | 0.28 | 0.09 | 0.04 | 0.01 | ||
| 2037 | 1146 | 733 | 509 | 286 | |||
| 800 | 0.34 | 0.14 | 0.03 | ||||
| 1467 | 1019 | 573 | |||||
| 1600 | 0.12 | ||||||
| 1146 | |||||||
Air velocity should not exceed certain limits to avoid unacceptable noise generation.
Air Ducts Friction Loss Calculator - SI Units
This pressure loss calculator is based on formula (1) with input and output values modified for SI units.
Air Ducts - Velocity and Friction Loss - Excel Template
This Excel template can be used to calculate velocity and friction loss in air ducts.
The chart below can be used to estimate friction loss in air ducts.
The default values are for air flow 400 cfm (680 m3/h) , duct size 8 in (200 mm) and friction loss 0.28 inH2O/100ft (2.3 Pa/m) .
• Ventilation Systems
Air Duct Velocities
Typical air duct velocities in applications like ventilation systems or compressed air systems.
A major friction loss diagram for air ducts - SI units.
Air Ducts - Velocity Diagram
Air flow volume, duct size, velocity and dynamic pressure.
The equal friction method for sizing air ducts is easy and straightforward to use.
Duct Systems - Pressure Classifications
Duct systems are commonly divided into three pressure classifications.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ductwork - Seal Classes
Ductwork air leakage classes.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
Sizing Circular Ducts
A rough guide to maximum air volume capacity of circular ducts in comfort, industrial and high speed ventilation systems.
Spiral Ducts - Dimensions
Standard dimensions of spiral ducts - Imperial units.
Velocity Classification of Ventilation Ducts
Recommended air velocities in ventilation ducts
