Duct Systems - Pressure Classifications
Duct systems are often divided into three pressure classifications:
  • Low Pressure Systems - where fan static pressures are less than 3 in WC (750 Pa) and duct velocities in general less than 1500 fpm (7.5 m/s)
  • Medium Pressure Systems - where fan static pressures are in the range 3 to 6 in WC (750 - 1500 Pa) and duct velocities in general less than 2500 fpm (12.5 m/s)
  • High Pressure Systems - where fan static pressures are in the range 6 to 10 in WC (1500 - 2500 Pa) and duct velocities in general less than 4000 fpm (20 m/s)
Medium pressure classification is commonly used for primary main ductwork like fan connections, risers and main distribution.
Low pressure classification should be used for secondary ductwork like runouts and branches from main ducts to end terminals.
Ventilation
Air Ducts - Major Friction Head Loss, Online Calculator
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Classification of Ventilation Systems
Ventilation systems can be classified by functions, distribution strategies or by ventilation principles.
The equal friction method for sizing air ducts is easy and straightforward to use.
HVAC Ducts - Air Velocities
Recommended air velocities in HVAC ducts.
Pressure
Static Pressure in a HVAC System
A minimum static pressure is required in a HVAC system to keep the water in the highest levels of the system.
Velocity Classification of Ventilation Ducts
Recommended air velocities in ventilation ducts
