Flow Section Channels - Geometric Relationships
Area, wetted perimeter and hydraulic diameter for geometric sections like
  • rectangular channels
  • trapezoidal channels
  • triangular channels
  • circular channels
Rectangular Channel
Flow Area
Flow area of a rectangular channel:
A = b h                               (1)
A = flow area (m 2 , in 2 )
b = width of channel (m, in)
h = height of flow (m, in)
Wetted Perimeter
Wetted perimeter of a rectangular channel:
P = b + 2 h                         (1b)
P = wetted perimeter (m, in)
Hydraulic Radius
Hydraulic radius of a rectangular channel:
R h = b h / (b + 2 h)                   (1c)
R h = hydraulic radius (m, in)
Trapezoidal Channel
Flow Area
Flow area of a trapezoidal channel:
A = h (b + T) / 2                      (2)
Wetted Perimeter
Wetted perimeter of a trapezoidal channel:
P = b + 2 (((T - b) / 2) 2 + h 2 ) 1/2 (2b)
Hydraulic Radius
Hydraulic radius of a trapezoidal channel:
R h = ( h (b + T) / 2) / ( b + 2 (((T - b) / 2) 2 + h 2 ) 1/2 )                       (2c)
Triangular Channel
Flow Area
Flow area of a triangular channel:
A = z h 2 (3)
z = see figure above (m, in)
Wetted Perimeter
Wetted perimeter of a triangular channel:
P = 2 h (1 + z 2 ) 1/2 (3b)
Hydraulic Radius
Hydraulic radius of a triangular channel:
R h = z h / 2 (1 + z 2 ) 1/2 (3c)
Circular Channel
Flow Area
Flow area of a circular channel:
A = D 2 /4 (α - sin(2 α)/2)                      (4)
D = diameter of channel
α = cos -1 (1 - h/r)
Wetted Perimeter
Wetted perimeter of a circular channel:
P = α D                      (4b)
Hydraulic Radius
Hydraulic radius of a circular channel:
R h = D/4 [1 - sin(2 α) / (2 α)]                     (4c)
Fluid Mechanics
California Pipe Flow Metering Method
Calculate the discharge length from the open end of a partially filled horizontal pipe.
Chezys Conduit Flow Equation
Calculating volume flow and velcity in open conduits.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Rectangular Ducts - Hydraulic Diameter
Calculate hydraulic diameter for rectangular ducts - metric units.
