In the discharge on a horizontal 4 inches PVC sewer pipe the distance from the top inside pipe to the water flow is 3 inches (0.25 ft). The inside diameter of the PVC pipe is 4.069 in (0.34 ft).
The discharge can be calculated as
q = 8.69 (1 - (0.25 ft) / (0.34 ft))1.88 (0.34 ft)2.48
= 0.049 ft3/s
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Geometric relationships like area, wetted perimeter and hydraulic diameter.
Turndown ratio (Rangeability) can be used to compare flow measurement devices like orifices, venturi meters etc.
Calculate cross-sectional average velocity flow in open channels.
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
Pitot tubes can be used to measure fluid flow velocities by measuring the difference between static and dynamic pressure in the flow.
Sluice gates can be used to control and measure volume flow rates in open channels and rivers, mainly in connection to hydro power plants.
An basic introduction to the ultrasonic Doppler and Time of Flight Flow Meters.
The vortex shedding frequency created around a bluff body and flow rate.
A manual providing guidance in selecting, managing, inspecting, and maintaining water measurement devices - describes standard methods and devices commonly used to measure irrigation water.
