Vortex Flowmeters - Shedding Frequency vs. Volume Flow Rate
Vortex Shedding Frequency
The vortex shedding frequency around a bluff body can be calculated as
f = Sr v / d (1)
f = vortex shedding frequency (Hz)
Sr = Strouhal number (dimensionless)
v = flow velocity (m/s)
d = bluff body diameter
Volumetric Flowrate
The volumetric flowrate from the shredding frequency can be calculated as
q = A f / k (2)
q = volumetric flowrate (m3/s)
A = cross sectional area of the vortex orifice (m2)
k = a constant for all fluids given design of meter
• Flow Measurement
California Pipe Flow Metering Method
Calculate the discharge length from the open end of a partially filled horizontal pipe.
Comparing Flowmeters
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Strouhal Number
Introduction to the Strouhal Number
Vortex Flowmeters
An introduction to vortex flowmeters.
