Vortex Flowmeters
Vortex flowmeters, also know as vortex shedding flowmeters or oscillatory flowmeters, measure the vibrations of the downstream vortexes caused by a barrier in the moving stream.
The vibrating frequency of the vortex shedding is related to the velocity of the flow.
• Flow Measurement
Comparing Flowmeters
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Flowmeter - Accuracy
Strouhal Number
Introduction to the Strouhal Number
Vortex Flowmeters - Shedding Frequency vs. Volume Flow Rate
The vortex shedding frequency created around a bluff body and flow rate.
