Comparing Flowmeters
A comparison of fluid flow meters:
Electromagnetic
Electromagnetic flow meters - or induction flow meters - function with conductive fluids by measuring flow across a controlled magnetic field.
  • Suitable for: clean and dirty viscous conductive liquids and slurries with high level of solids, turbulent or laminar flow
  • Not suitable for: hydrocarbons and fluids with low conductivity, partly filled pipes, gas flow
  • Accuracy: ± 0.5 - 1 % of rate
  • Rangeabliity: typical 40:1
  • Pressure drop: none
  • Required upstream pipe (diameters): 5
  • Relative cost: high
  • Effect of viscosity: none
  • Moving parts: none
  • Pipe size: wide range
  • Corrosion: can be made with liners suited for corrosive fluids
Mass - Coriolis
Mass flow meters based on the Coriolis effect.
  • Suitable for: clean and dirty liquids, gases and slurries - can be used to monitor concentration and solids content. Suitable for applications where temperature and pressures fluctuate.
  • Not suitable for:
  • Accuracy: ± 0.05 - 0.5 % of rate
  • Rangeabliity: typical 10:1
  • Pressure drop: low
  • Required upstream pipe (diameters): none
  • Pipe size: limited range
  • Corrosion:
Mass - Thermal
Mass flow meters based on the thermal cooling effect of the flowing fluid.
  • Suitable for: clean and dirty liquids, even some slurries
  • Not suitable for:
  • Accuracy: ± 1 % of rate
  • Corrosion:
Orifice
With orifice flow meters the pressure difference over an orifice in the flow is measured. Measured pressure difference is proportional with flow velocity squared.
  • Suitable for: clean and dirty liquids and for some slurries
  • Accuracy: ± 2 - 4 % of scale
  • Rangeabliity: typical 4:1
  • Pressure drop: medium - pressure drop required for measurement
  • Required upstream pipe (diameters): 10 - 30
  • Relative cost: low
  • Effect of viscosity: sensible
  • Corrosion: can be adapted for some corrosive liquids
Turbine
Turbine flow meters are made with bladed turbine rotors mounted axially in the meter. When fluid flows through the meter the rotor spins at a speed proportional to the velocity of the fluid. The spin is detected with a magnetic pick up with typically a pulse output.
  • Suitable for: clean viscous liquids and gases, turbulent flow
  • Not suitable for: corrosive fluids and liquids with solids
  • Accuracy: ± 0.25 % of rate
  • Rangeabliity: typical 20:1
  • Pressure drop: higher, back pressure required to avoid cavitation, bubbles in the liquid will affect accuracy
  • Required upstream pipe (diameters): 5 - 10
  • Relative cost: medium
  • Moving parts: rotor
  • Corrosion: moveable components not suited for corrosive fluids
Ultrasonic
Ultrasonic flow meters are non-invasive volume flow meters based on transit-time (Time of travel) or Doppler effect technology. A transit-time flow meter measures the frequency shift (difference) between upstream and downstream ultrasonic pulses projected into and across the pipe. The frequency shift is proportional to flow velocity. A Doppler flow meters measure the frequency shift when an ultrasonic signal is reflected by suspended particles or gas bubbles in motion. The frequency shift is proportional to flow velocity.
  • Suitable for: clean (transmit-time) and dirty (Doppler) liquids
  • Not suitable for: gases
  • Accuracy: ± 1 - 5 % of full scale
  • Rangeabliity: typical 10:1 (Doppler), 20:1 (transmit-time)
  • Required upstream pipe (diameters): 5 - 30
Vortex
Vortex flow meters are made with an obstruction object mounted in flow. When fluid flows through the meter an alternating vortex is created downstream the object. The vortex frequency is proportional with the flow and is detected with a pressure sensor, thermistor or ultrasonic sensor.
  • Suitable for: clean and dirty liquids and gases - including steam, turbulent flow
  • Not suitable for: high viscosity fluids
  • Required upstream pipe (diameters): 10 - 20
  • Effect of viscosity: sensible for fluids with high viscosity
  • Corrosion: no moving components - can be adapted for corrosive fluids
Wedge
Wedge is used as primary element in flow measurement of liquid, gas and steam according to the differential pressure principle.
  • Suitable for: slurries and viscous liquids
  • Accuracy: ± 0.5 - 5 % of scale
  • Rangeabliity: typical 3:1
  • Pressure drop: low to medium - pressure drop is required for measurement
  • Effect of viscosity: low
V-Cone
A V-cone flow meter a differential pressure instrument where the differential pressure is measured before and after a cone located in the flow.
  • Suitable for pharmaceuticals, oil, gas, chemical, food and beverage, plastics, district HVAC, textile, power and water and wastewater applications
  • Can be used for fluids with sand and dust
  • Can be used in high pressure and temperature applications
  • Accuracy: ± 0.5 %
  • Repeatability: ± 0.1 %
  • Low maintenance - no moving parts
  • Long life time
  • Require little space - suitable for retrofit
Flow Measurements
California Pipe Flow Metering Method
Calculate the discharge length from the open end of a partially filled horizontal pipe.
Decibel A, B and C
Electromagnetic Flowmeters
An introduction to electromagnetic flowmeters and their principles.
Flowmeter - Accuracy
Flowmeters - Turndown Ratios
Turndown ratio (Rangeability) can be used to compare flow measurement devices like orifices, venturi meters etc.
Open Channel Weirs - Volume Flow Measurements
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
Orifice, Nozzle, and Venturi Flow Meters: Principles, Calculations & Data
Pitot Tubes
Pitot tubes can be used to measure fluid flow velocities by measuring the difference between static and dynamic pressure in the flow.
ISA process instrumentation codes - and combinations.
Target - Volume Flow Meters
Introduction to the target flow meters principles.
U-Tube Differential Pressure Manometers
Inclined and vertical u-tube manometers used to measure differential pressure in flow meters like pitot tubes, orifices and nozzles.
Ultrasonic Doppler and Time of Flight Velocity and Volume Flow Meters
An basic introduction to the ultrasonic Doppler and Time of Flight Flow Meters.
Velocity-Area Flowmetering
Flow rate or discharge in an open conduit, channel or river can be calculated with the velocity-area principle.
Vortex Flowmeters
An introduction to vortex flowmeters.
Vortex Flowmeters - Shedding Frequency vs. Volume Flow Rate
The vortex shedding frequency created around a bluff body and flow rate.
Water - Volume Flow Measurement
A manual providing guidance in selecting, managing, inspecting, and maintaining water measurement devices - describes standard methods and devices commonly used to measure irrigation water.
