Electromagnetic Flowmeters
A tutorial introduction to electromagnetic flow meters.
http://www.omega.com/literature/transactions/volume4/T9904-09-ELEC.html#elec_2
Flow Measurement
Comparing Flowmeters
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Flowmeter - Accuracy
Flowmeters - Turndown Ratios
Turndown ratio (Rangeability) can be used to compare flow measurement devices like orifices, venturi meters etc.
