Velocity-Area Flowmetering
The velocity-area principle is based on velocity measurements in a open flow like a conduit, channel or river.
Velocities and depths across the stream are measured as indicated in the figure above. A partial discharge in a section of the stream can be calculated as
qn = vn an (1)
qn = flow rate or discharge in section n (m3/s, ft3/s)
vn = measured velocity in section n (m/s, ft/s)
an = area of section n (m2, ft2)
One simple way to express the section area is
an = dn (ln+1 - ln-1) / 2 (2)
The total flow in the stream can be summarized to
Q = Σ1n vn an (3)
Q = summarized flow rate or discharge in the conduit (m3/s, ft3/s)
The accuracy of estimate depends on the profile of the conduit and the number of measurements. For conduits with regular shapes like rectangular channels a limited number of measurements are required. For irregular shapes - like natural rivers or similar - higher accuracy requires more measurements both horizontal and vertical.
Example - Computing Flow Rate in a Channel
From a conduit we have three measurements:
Measured Values | Calculated Values | ||||
n | v (m/s) | d (m) | l (m) | a (m2) | q (m3/s) |
0 | 0 | 0 | 0 | ||
1 | 3 | 1 | 2 | 2 | 6 |
2 | 4 | 1.5 | 4 | 3 | 12 |
3 | 3 | 0.9 | 6 | 1.8 | 5.4 |
4 | 0 | 0 | 8 | ||
Summarized | 23.4 |
The section areas can be calculated like
a1 = (1 m) ((4 m) - (0 m)) / 2
= 2 m2
a2 = (1.5 m) ((6 m) - (2 m)) / 2
= 3 m2
a3 = (0.9 m) ((8 m) - (4 m)) / 2
= 1.8 m2
The flow rates can be calculated as
q1 = (3 m/s) (2 m2)
= 6 m3/s
q2 = (4 m/s) (3 m2)
= 12 m3/s
q3 = (3 m/s) (1.8 m2)
= 5.4 m3/s
The total flow can be summarized as
Q = (6 m3/s) + (12 m3/s) + (5.4 m3/s)
= 23.4 m3/s
Note - there are alternative ways to calculate the section flow rates:
Simple Average Method
Using the simple average of two successive vertical depths, their mean velocity, and the distance between them can be expressed as
qn to n+1 = ((vn + vn+1) / 2) ((dn + dn+1) / 2) (ln+1 - ln) (4)
Midsection Method
With the midsection method, the depth and mean velocity are measured for each number of verticals along the cross section. The depth at a vertical is multiplied by the width, which extends halfway to the preceding vertical and halfway to the following vertical, to develop a cross-sectional area. The section flow rate can be expressed as
qn = vn (((ln - ln-1) + (ln+1 - ln)) / 2) dn (5)
• Flow Measurements
Comparing Flowmeters
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Flowmeter - Accuracy
Flowmeters - Turndown Ratios
Turndown ratio (Rangeability) can be used to compare flow measurement devices like orifices, venturi meters etc.
Open Channel Weirs - Volume Flow Measurements
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
Orifice, Nozzle, and Venturi Flow Meters: Principles, Calculations & Data
Sluice Gate - Volume Flow Measurements
Sluice gates can be used to control and measure volume flow rates in open channels and rivers, mainly in connection to hydro power plants.
U-Tube Differential Pressure Manometers
Inclined and vertical u-tube manometers used to measure differential pressure in flow meters like pitot tubes, orifices and nozzles.
Velocity Pressure Head
Dynamic pressure or velocity head.
Water - Volume Flow Measurement
A manual providing guidance in selecting, managing, inspecting, and maintaining water measurement devices - describes standard methods and devices commonly used to measure irrigation water.
