Strouhal Number
The Strouhal Number is a dimensionless value useful for analyzing oscillating unsteady fluid flow dynamics problems.
The Strouhal Number can be expressed as
St = ω l / v                                             (1)
St = Strouhal Number
ω = oscillation frequency
l = characteristic length
v = flow velocity
The Strouhal Number can be important when analyzing unsteady, oscillating flow problems. The Strouhal Number represents a measure of the ratio of the inertial forces due to the unsteadiness of the flow or local acceleration to the inertial forces due to changes in velocity from one point to an other in the flow field.
The vortices observed behind a stone in a river, or measured behind the obstruction in a vortex flow meter, illustrates these principles.
Fluid Mechanics
Dimensionless Numbers
Physical and chemical dimensionless quantities - Reynolds number, Euler, Nusselt, and Prandtl number - and many more.
Technical Terms in Fluid Mechanics
Some commonly used technical terms in fluid mechanics.
Vortex Flowmeters
An introduction to vortex flowmeters.
Vortex Flowmeters - Shedding Frequency vs. Volume Flow Rate
The vortex shedding frequency created around a bluff body and flow rate.
