Wind Load vs. Wind Speed
When moving air - wind - is stopped by a surface - the dynamic energy in the wind is transformed to pressure. The pressure acting the surface transforms to a force
Fw = pd A
= 1/2 ρ v2 A (1)
Fw = wind force (N)
A = surface area (m2)
pd = dynamic pressure (Pa)
ρ = density of air (kg/m3)
v = wind speed (m/s)
Note - in practice wind force acting on a object creates more complex forces due to drag and other effects.
Wind Load Calculator
| Wind Speed (m/s) | Wind Load1) (Pa) |
| 1 | 0.6 |
| 2 | 2.4 |
| 3 | 5.4 |
| 4 | 9.6 |
| 5 | 15 |
| 6 | 22 |
| 7 | 29 |
| 8 | 38 |
| 9 | 49 |
| 10 | 60 |
| 11 | 73 |
| 12 | 86 |
| 13 | 101 |
| 14 | 118 |
| 15 | 135 |
| 16 | 154 |
| 17 | 173 |
| 18 | 194 |
| 19 | 217 |
| 20 | 240 |
| 21 | 265 |
| 22 | 290 |
| 23 | 317 |
| 24 | 346 |
| 25 | 375 |
| 26 | 406 |
| 27 | 437 |
| 28 | 470 |
| 29 | 505 |
| 30 | 540 |
| 31 | 577 |
| 32 | 614 |
| 33 | 653 |
| 34 | 694 |
| 35 | 735 |
| 36 | 778 |
| 37 | 821 |
| 38 | 866 |
| 39 | 913 |
| 40 | 960 |
| 41 | 1009 |
| 42 | 1058 |
| 43 | 1109 |
| 44 | 1162 |
| 45 | 1215 |
| 46 | 1270 |
| 47 | 1325 |
| 48 | 1382 |
| 49 | 1441 |
| 50 | 1500 |
1) density of air 1.2 kg/m3
- 1 m/s = 3.6 km/h = 196.85 ft/min = 2.237 mph
- 1 Pa = 1 N/m2 = 1.4504×10-4 psi (lb/in2)
Example - Hurricane Wind Load acting on a Wall Surface
A hurricane with wind speed 35 m/s is acting on a 10 m2 wall. The dynamic force can be calculated as
Fw = 1/2 ρ v2 A
= 1/2 (1.2 kg/m3) (35 m/s)2 (10 m2)
= 7350 N
= 7.35 kN
Or - from the table above the wind load per square metre is 735 N/m2. The total load on the wall can be calculated as
(735 N/m2) (10 m2) = 7350 N
A hurricane acting on a 10 m2 wall creates a force equal to the weight of aprox. 750 kg.
• Mechanics
Air Curtains or Air Screens
Calculate air curtains or air screens in open doorways used to keep acceptable indoor comfort in buildings.
Beaufort's Wind Scale
The Beaufort description and observation scale for wind and wind speed.
Distance Traveled vs. Speed and Time - Calculator and Chart
Velocity plotted in time used diagram.
Drag Coefficient
The drag coefficient quantifies the drag or resistance of an object in a fluid environment.
Dynamic Pressure
Dynamic pressure is the kinetic energy per unit volume of a fluid in movement.
Force
Fujita-Pearson Tornado Intensity Scale
A tornado intensity rating scale.
Hurricane Intensity Scale
The Saffir-Simpson hurricane damage potential scale.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Wind Chill Index
Effective Temperature of air in movement.
Wind Energy
Available wind energy.
Wind Power
Power generation from wind.
Wind Shear
Wind slowed down at surface by trees and obstructions.
Wind Turbine Power Calculator
Online wind turbine calculator.
