Dynamic Pressure
Dynamic pressure is the kinetic energy of a flowing fluid - liquid or gas - per unit volume - and can be expressed as
p d = 1/2 ρ v 2 (1)
p d = dynamic pressure (N/m 2 (Pa), lb f /ft 2 (psf))
ρ = density of fluid (kg/m 3 , slugs /ft 3 )
v = velocity (m/s, ft/s)
Dynamic Pressure Calculator - SI Units
The default values below are for water with density of 1000 kg/m 3 .
  • 1 N/m 2 = 1 Pa = 1.4504x10 -4 lb f /in 2 (psi) = 0.02089 lb f /ft 2 (psf) = 1x10 -5 bar = 4.03x10 -3 in water = 0.336x10 -3 ft water = 0.1024 mm water = 0.295x10 -3 in mercury = 7.55x10 -3 mm mercury = 0.1024 kp/m 2 = 0.993x10 -5 atm
Dynamic Pressure Calculator - Imperial Units
The default values below are for water with density of 1.940 slugs .
Some common densities at atmospheric pressure:
  • Water - 0 o C - 1000 kg/m 3
  • Water - 32 o F - 1.940 slugs/ft 3
  • Air - 20 o C - 1.2 kg/m 3
  • Air - 60 o F - 2.373 10 -3 slugs/ft 3
Example - The Dynamic Pressure in a Water Flow
The dynamic pressure in water with - temperature 20 o C - density 1000 kg/m 3 and velocity 5 m/s - can be calculated as
p d = 1/2 (1000 kg/m 3 ) (5 m/s) 2
= 12500 Pa
= 12.5 kPa
Example - Hurricane and Force acting on a Wall
The dynamic pressure in a hurricane with air temperature 20 o C, density of air 1.2 kg/m 3 and wind speed 37 m/s can be calculated as
p d = 1/2 (1.2 kg/m 3 ) (37 m/s) 2
= 821 Pa (N/m 2 )
The force acting directly on a wall with area 10 m 2 can be calculated as
F = p d A
= (821 N/m 2 ) (10 m 2 )
= 8210 N
= 8.2 kN
- almost the weight of a small car.
Note! - the real force acting on the wall - or an other obstruction in the wind - is in general more complicated to calculate due to drag , turbulence and other effects.
Fluid Mechanics
Air Curtains or Air Screens
Calculate air curtains or air screens in open doorways used to keep acceptable indoor comfort in buildings.
Beaufort's Wind Scale
The Beaufort description and observation scale for wind and wind speed.
Distance Traveled vs. Speed and Time - Calculator and Chart
Velocity plotted in time used diagram.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Pitot Tubes
Pitot tubes can be used to measure fluid flow velocities by measuring the difference between static and dynamic pressure in the flow.
Velocity Pressure Head
Dynamic pressure or velocity head.
Wind Load vs. Wind Speed
Wind load on surface - Wind load calculator.
