Wind Chill Index
The convective heat loss due to wind can be dramatic. In the table below the wind chill effect is illustrated for air speeds up to 10 m/s (36 km/h, 2000 ft/min, 22 mph), or "fresh breeze" according the Beaufort wind scale.
Wind Chill Effect
Air SpeedChill Effect
(m/s)(ft/min)(oC)(oF)
0.1 20 0 0
0.25 50 0.5 2
1.5 300 4 7
3 600 6 10.5
5 1000 7 13
8 1575 8 15
10 2000 9 16
Wind Chill Index - Wind Speed in km/h and Temperature in degrees Celsius
"Chilled" air temperature can be expressed as a function of wind speed and ambient air temperature
twC = 13.12 + 0.6215 ta - 11.37 v0.16 + 0.3965 ta v0.16                        (1)
twC = effective "wind" temperature (oC)
ta = air temperature (oC)
v = wind speed (km/h)
Wind Chill Index -  SI Units
"Chilled" Air Temperature (oC)
Ambient Air Temperature (oC)Wind Speed (km/h)
510152030405060
10 10 9 8 7 7 6 5 5
5 4 3 2 1 0 -1 -1 -2
0 -2 -3 -4 -5 -6 -7 -8 -9
-5 -7 -9 -11 -12 -13 -14 -15 -16
-10 -13 -15 -17 -18 -20 -21 -22 -23
-15 -19 -21 -23 -24 -26 -27 -29 -30
-20 -24 -27 -29 -30 -33 -34 -35 -36
-25 -30 -33 -35 -37 -39 -41 -42 -43
-30 -36 -39 -41 -43 -46 -48 -49 -50
-35 -41 -45 -48 -49 -52 -54 -56 -57
-40 -47 -51 -54 -56 -59 -61 -63 -64
  • 1 km/h = 0.2778 m/s = 54.68 ft/min = 0.6214 mph = 0.5396 knot
Download and print Wind Chill Index chart
Wind Chill Index - Wind Speed in mph and Temperature in degrees Fahrenheit
The "Chilled" air temperature can also be expressed as a function of wind velocity and ambient air temperature as
twF = 35.74 + 0.6215 ta - 35.75 v0.16 + 0.4275 ta v0.16                        (2)
twF = effective temperature (oF)
ta = air temperature (oF)
v = wind speed (mph)
Wind Chill Index - Imperial Units
"Chilled" Air Temperature (oF)
Ambient Air Temperature (oF)Wind Speed (mph)
510152025303540
40 36 34 32 30 29 28 28 27
35 31 27 25 24 23 21 21 20
30 25 21 19 17 16 14 14 13
25 19 15 13 11 9 7 7 6
20 13 9 6 4 3 0 0 -1
15 7 3 0 -2 -4 -7 -7 -8
10 1 -4 -7 -9 -11 -14 -14 -15
5 -5 -10 -13 -15 -17 -21 -21 -22
0 -11 -16 -19 -22 -24 -27 -27 -29
-5 -16 -22 -26 -29 -31 -37 -34 -36
-10 -22 -28 -32 -35 -37 -41 -41 -43
-15 -28 -35 -39 -42 -44 -48 -48 -50
-20 -34 -41 -45 -48 -51 -55 -55 -57
-25 -40 -47 -51 -55 -58 -62 -62 -64
-30 -46 -53 -58 -61 -64 -69 -69 -71
-35 -52 -59 -64 -68 -71 -76 -76 -78
-40 -57 -66 -71 -74 -78 -82 -82 -84
Wind Chill Effects
Wind ChillPossible Effects
30 oF or higher Generally unpleasant
30o to 15 oF Unpleasant
14o to 0 oF Very unpleasant
-1o to -20 oF Frostbite possible
-21o to -60 oF Frostbite likely - outdoor activities dangerous
-61o or lower Exposed flesh freezes within 30 seconds
Environment
Physiology
Beaufort's Wind Scale
The Beaufort description and observation scale for wind and wind speed.
Fujita-Pearson Tornado Intensity Scale
A tornado intensity rating scale.
Hurricane Intensity Scale
The Saffir-Simpson hurricane damage potential scale.
Survival Time in Cold Water
Time to exhaustion and death for humans in cold water.
Understanding Convective Heat Transfer: Coefficients, Formulas & Examples
Wind Load vs. Wind Speed
Wind load on surface - Wind load calculator.
