Liquids - Specific Gravities
Specific gravity of a liquid is the "ratio of the density of the liquid - to the density of water at 4 oC".
Specific gravity of some common liquids and fluids:
| Fluid | Temperature (oC) | Specific Gravity SG |
| Acetic Acid | 25 | 1.052 |
| Acetone | 25 | 0.787 |
| Acetonitrile | 20 | 0.783 |
| Acetylene, liquid | -121 oF | 0.62 |
| Acetylene, liquid | 70 oF | 0.38 |
| Adipic acid | 0.72 | |
| Alcohol, ethyl (ethanol) | 25 | 0.787 |
| Alcohol, methyl (methanol) | 25 | 0.791 |
| Alcohol, propyl | 25 | 0.802 |
| Ammonia (aqua) | 25 | 0.826 |
| Aniline | 25 | 1.022 |
| Beer | 25 | 1.01 |
| Benzene | 25 | 0.876 |
| Benzil | 25 | 1.084 |
| Bromine | 25 | 3.12 |
| Butane, liquid | 25 | 0.601 |
| 1-Butanol | 20 | 0.815 |
| Butylamine | 20 | 0.742 |
| Caproic acid | 25 | 0.924 |
| Carbolic acid | 15 | 0.959 |
| Carbon disulfide | 25 | 1.265 |
| Carbon tetrachloride | 25 | 1.589 |
| Carene | 25 | 0.860 |
| Oil, Castor | 25 | 0.959 |
| Chloride | 25 | 1.56 |
| Chlorine | 60 oF | 1.42 |
| Chlorobenzene | 20 | 1.11 |
| Chloroform | 25 | 1.469 |
| Citric acid | 25 | 1.665 |
| Coconut Oil | 15 | 0.925 |
| Corn (maize) oil | 15.5 | 0.923 |
| Cotton Seed Oil | 15 | 0.923 |
| Cresol | 25 | 1.027 |
| Creosote | 15 | 1.070 |
| Crude oil, California | 60 oF | 0.918 |
| Crude oil, Mexican | 60 oF | 0.976 |
| Crude oil, Texas | 60 oF | 0.876 |
| Cumene | 25 | 0.862 |
| Cyclohexane | 20 | 0.779 |
| Decane | 25 | 0.728 |
| 1-Decanol | 20 | 0.829 |
| Dichloromethane | 20 | 1.32 |
| Dodecane | 25 | 0.757 |
| Ethane | -89 | 0.572 |
| Ethanol | 20 | 0.789 |
| Ether (Diethyl ether) | 25 | 0.716 |
| Ethyl acetate | 20 | 0.901 |
| Ethylamine | 16 | 0.683 |
| Ethyl benzene | 20 | 0.867 |
| Ethyl formate | 20 | 0.922 |
| Ethyl propanoate | 20 | 0.890 |
| Ethylene glycol | 25 | 1.100 |
| Trichlorofluoromethane refrigerant R-11 | 25 | 1.480 |
| Dichlorodifluoromethane refrigerant R-12 | 25 | 1.315 |
| Chlorodifluoromethane refrigerant R-22 | 25 | 1.197 |
| Formaldehyde | 45 | 0.815 |
| Fuel oil | 60 oF | 0.893 |
| Furan | 25 | 1.421 |
| Furforal | 25 | 1.159 |
| Gasoline, natural | 60 oF | 0.713 |
| Gasoline, Vehicle | 60 oF | 0.739 |
| Glycerine (glycerol 95%, water 5%) | 25 | 1.249 |
| Glycerol | 25 | 1.261 |
| Glycol | 25 | 1.11 |
| Heptane | 25 | 0.681 |
| Hexane | 25 | 0.657 |
| 1-Hexanol | 25 | 0.813 |
| Hexene | 25 | 0.673 |
| Hydrazine | 25 | 0.797 |
| Iodine (at solid state) | 20 | 4.933 |
| Isopropylbenzene | 20 | 0.862 |
| Kerosene | 60 oF | 0.820 |
| Linolenic Acid | 25 | 0.902 |
| Linseed Oil | 25 | 0.932 |
| Mercury | 25 | 13.633 |
| Methane | -164 | 0.466 |
| Methanol | 20 | 0.791 |
| Methyl acetate | 20 | 0.935 |
| Methylcyclohexane | 20 | 0.769 |
| Methyl formate | 20 | 0.974 |
| Methyl propanoate | 20 | 0.915 |
| Milk | 1.035 | |
| Naphtha, Petroleum Naphtha | 15 | 0.667 |
| Nitromethane | 20 | 1.14 |
| Napthalene | 25 | 0.963 |
| Nonane | 20 | 0.718 |
| Nonanol | 25 | 0.823 |
| Octane | 25 | 0.701 |
| Olive Oil | 15 | 0.915 |
| Oxygen | -183 | 1.14 |
| Palm Oil | 15.5 | 0.923 |
| Palm Kernel Oil | 15.5 | 0.912 |
| Palmitic Acid | 25 | 0.853 |
| Peanut (Arachis) Oil | 15.5 | 0.92 |
| Pentane | 25 | 0.755 |
| Pentanoic acid | 20 | 0.939 |
| Phenol | 25 | 1.075 |
| Phosgene | 0 | 1.381 |
| Phytadiene | 25 | 0.826 |
| Pinene | 25 | 0.858 |
| Propane | -40 | 0.585 |
| Propane | 25 | 0.495 |
| 1-Propanol | 20 | 0.805 |
| 2-Propanol | 20 | 0.786 |
| Propyl acetate | 20 | 0.889 |
| Propylbenzene | 20 | 0.862 |
| Propylene | 25 | 0.516 |
| Propylene glycol | 25 | 1.036 |
| Propyl formate | 20 | 0.905 |
| Pyridine | 25 | 0.968 |
| Parole | 25 | 0.969 |
| Rapeseed Oil | 15.5 | 0.915 |
| Resorcinol | 25 | 1.272 |
| Sabiname | 25 | 0.814 |
| Safflower Oil | 15.5 | 0.922 |
| Sea water | 25 | 1.028 |
| Silane | 25 | 0.719 |
| Soja Beans Oil | 15.5 | 0.926 |
| Sorbaldehyde | 25 | 0.898 |
| Stearic Acid | 25 | 0.941 |
| Styrene | 25 | 0.906 |
| Sunflower Oil | 15.5 | 0.925 |
| Terpinene | 25 | 0.850 |
| Tetrachloromethane | 20 | 1.59 |
| Toluene | 25 | 0.865 |
| Trichlormethane | 20 | 1.49 |
| Turpentine | 25 | 0.871 |
| Water, pure | 39.1 oF (4 oC) | 1.000 |
| Water, sea | 77 oF | 1.025 |
| o-Xylene | 20 | 0.880 |
| m-Xylene | 20 | 0.864 |
| p-Xylene | 20 | 0.861 |
- T (oC) = 5/9 (T (oF) - 32)
- T(oF) = (T(oC))(9/5) + 32
• Densities
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Baume's Hydrometer
Liquid density with Degree Baume vs. Specific Gravity.
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Hydrocarbons - Physical Data
Liquid Densities
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Sugar Solubility in Water
Solubility of sugar in water.
Toluene Liquid - Thermal Properties vs. Temperature
Density, specific heat, thermal conductivity and more.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
