Be aware of the concentration units in the figures:
wt%: Mass of solute/total mass of solution ×100%
mol/kg: Molality = moles of solute/kg of water
mol/liter: Molarity = moles of solute/liter of solution
Values are tabulated below the figures.
See also density of aqueous solutions of organic acids, inorganic chlorides, inorganic sodium salts, inorganic potassium salts and some other inorganic substances
Density of aqueous solutions at 20°C, given as g/cm3:
For full table with Glycerol, b-D-Lactose, a-Maltose, D-Mannitol, Methanol, 1-propanol, 2-propanol, Sucrose and Urea - rotate the screen!
Aqueous Solutions of Organic Substances as Sugars and Alcohols - Densities
Mass%Acetone1,2-EthanediolEthanolb-D-Fructosea-D-GlucoseGlycerolb-D-Lactosea-MaltoseD-MannitolMethanol1-propanol2-propanolSucroseUrea
1 0.9968 0.9995 0.9963 1.0021 1.0020 1.0005 1.0021 1.0003 1.0017 0.9964 0.9963 0.9960 1.0021 1.0007
5 0.9912 1.0044 0.9893 1.0181 1.0175 1.0097 1.0184 1.0184 1.0159 0.9896 0.9896 0.9884 1.0178 1.0111
10 0.9849 1.0108 0.9819 1.0385 1.0375 1.0215 1.0385 0.9816 0.9829 0.9816 1.0381 1.0248
20 1.0241 0.9687 1.0816 1.0797 1.0459 1.0801 0.9666 0.9686 0.9696 1.0810 1.0530
30 0.9539 1.1276 1.1260 1.1269 0.9514 1.1270 1.0812
40 1.0514 0.9352 1.1769 1.1724 1.0984 1.1769 0.9347 0.9288 0.9302 1.1765 1.1106
50 1.0650 0.9139 1.2235 1.2194 0.9156 1.2295
60 1.2793 1.1530 1.2855 0.8875 0.8824
70 0.8676 0.8715 1.3472
80 1.2085 0.8470 0.8341
100 0.7893 1.2611 0.7970 0.8034 0.7848
Density of aqueous solutions at 20°C, given as wt%
Conversion of the concentration from mass% to mol/kg (moles of solute/kg of water = molality):
Aqueous Solutions of Organic Substances as Sugars and Alcohols - Densities - Conversion of the concentration from mass% to mol/kg
1 0.170 0.163 0.219 0.056 0.056 0.110 0.030 0.015 0.055 0.315 0.168 0.168 0.030 0.168
5 0.876 0.848 1.142 0.292 0.292 0.572 0.154 0.154 0.289 1.643 0.876 0.876 0.154 0.876
10 1.913 1.790 2.412 0.617 0.617 1.207 0.325 0.250 0.610 3.468 1.849 1.849 0.325 1.850
20 4.028 5.427 1.388 1.388 2.715 0.730 7.803 4.160 4.160 0.730 4.163
30 9.303 2.379 2.379 1.252 13.376 1.252 7.136
40 10.741 14.471 3.700 3.700 7.239 1.948 20.807 11.093 11.093 1.948 11.100
50 21.706 5.551 2.921 31.211 2.921
60 24.166 8.326 16.288 4.382 24.958 24.958
70 50.648 72.826 6.817
80 43.436 66.556 66.556
Mol/kg solution at 20°C
Conversion of the concentration from mass% to mol/liter (moles of solute/liter of solution = molarity):
Aqueous Solutions of Organic Substances as Sugars and Alcohols - Densities - Conversion of the concentration from mass% to mol/liter
1 0.172 0.161 0.216 0.056 0.056 0.109 0.029 0.015 0.055 0.311 0.166 0.166 0.029 0.167
5 0.837 0.809 1.074 0.283 0.282 0.548 0.149 0.149 0.279 1.544 0.823 0.822 0.149 0.842
10 1.696 1.628 2.131 0.576 0.576 1.109 0.304 0.303 0.567 3.064 1.635 1.633 0.303 1.706
20 3.300 4.205 1.201 1.199 2.271 0.631 6.034 3.223 3.227 0.632 3.506
30 6.212 1.878 1.873 0.988 8.908 0.988 5.401
40 6.776 8.120 2.613 2.603 4.771 1.375 11.669 6.182 6.191 1.375 7.397
50 9.919 3.396 1.797 14.288 1.796
60 10.406 4.261 7.512 2.253 8.860 8.809
70 13.183 19.040 2.755
80 10.498 11.275 11.103
100 17.133 13.694 24.710 13.368 13.058
Mol/liter solution at 20°C
Densities
Material Properties
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Hydrocarbons - Physical Data
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Liquid Densities
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Naming of Organic Compounds
Nomenclature rules for different groups of organic compounds and functional groups, together with examples of use of the rules.
Propane Butane Mixture - Evaporation Pressure
Solids - Densities
Densities of selected solids.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
