ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Support span for PVC, Fiberglass and Steel pipes filled with cold water:
NPS
(inches)
DN
(mm)
Support Spacing (feet)
Standard Steel PipeFiberglass PipePVC Pipe
Schedule 80
1 25 7 12 4.5
1 1/2 40 9 14 5
2 50 10 15 5
3 80 12 17 6
4 100 14 19 7.5
6 150 17 22 8.5
8 200 19 24 9
10 250 22 27 9.5
  • specific gravity of water = 1.0 - temperature 60oF (15.56oC)
  • 1 ft (foot) = 0.3048 m
Support centers for ABS, PE and PVC pipes - schedule 40 and 80:
Dimensions
ABS Pipes - Pressure Ratings
Pressure ratings of ABS 1208, ABS 1210, ABS 1316 and ABS 2112.
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
Bending PE Pipes
Bending PE pipe calculator.
Fiberglass Pipes - common Standards
Commonly used standards for fiberglass pipes and their applications.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
Thermoplastic Pipes - Supporting Distances vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
