The maximum operating pressure of a PEH pipe depends on the temperature of fluid and pipe.
PN ratings are based on temperature 20 oC.
PE (PolyEthylene) Pipes - Maximum Operating Pressure vs. Temperature
Temperature
(oC)
Maximum Operating Pressure (bar)
PN 6PN 10PN 16
20 6.0 10.0 16.0
30 3.2 8.0 13.0
40 2.0 6.0 11.0
50 1.6 4.0 8.0
60 1.0 3.2 6.0
Example - Cold and Hot water Supply
The pressure in a water supply system to an area is 4 bar. The cold water temperature will never exceed 20 oC and the hot water distributed within the area with PEH pipes will never exceed temperature 50 oC.
From the table above pipes with PN 6 will do for the cold water. For the hot water PEH pipes PN 16  should be selected.
Pressure Ratings of Pipes and Fittings
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Bending PE Pipes
Bending PE pipe calculator.
Cement Lined Carbon Steel Pipes
Dimensions of cement lined carbon steel pipes.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Plastic Pipes - Friction Head Loss vs. Water Flow
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
