Standard Dimensions Ratio - SDR
Many plastic pipe manufacturers use the "Standard Dimension Ratio" - SDR - method of rating pressure piping. The SDR is the ratio of pipe diameter to wall thickness and the SDR can be expressed as
SDR = D / s (1)
D = pipe outside diameter (mm, in)
s = pipe wall thickness (mm, in)
Example - SDR
SDR for a 10 inches ASTM D2241 - PVC Pipe with outside diameter 10.750 inches and wall thickness 0.168 inches can be calculated as
SDR = (10.750 in) / (0.168 in)
= 64
A SDR 64 means that the outside diameter - D - of the pipe is 64 times the thickness - s - of the wall.
- with a high SDR ratio the pipe wall is thin compared to the pipe diameter
- with a low SDR ratio the pipe wall is thick compared to the pipe diameter
As a consequence a high SDR pipe has a low-pressure rating and low SDR pipe has a high-pressure rating.
Pipe Series - S
Pipe series - S - is a dimensionless number related to the nominal outside diameter and wall thickness of a pipe. The pipe series - S - can be calculated as
S = (SDR - 1) / 2 (2)
S = pipe series
• Dimensions
• Fluid Flow and Pressure Loss
• Pressure Ratings
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
Bending PE Pipes
Bending PE pipe calculator.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Plastic Pipes - Friction Head Loss vs. Water Flow
