ABS Pipes - Pressure Ratings
Water pressure ratings at 23 oC (73 oF) for schedule 40 ABS (Acrylonitrile Butadiene Styrene) plastic pipes with material designation
- ABS 2112
- ABS 1316
- ABS 1210
- ABS 1208
are indicated in the diagram below.
ABS Pipes - Schedule 40
Pressure psi
Pressure bar
ABS Pipes - Schedule 80
Pressure psi
Pressure bar
- thr - threaded pipe
ABS Material Designation
ABS 1210
- Material: Type I, Grade 2
- Code classification: 5-2-2
- Hydrostatic design stress: 1000 psi
ABS 1316
- Material: Type I, Grade 3
- Code classification: 3-5-5
- Hydrostatic design stress: 1600 psi
ABS 1210
- Material: Type II, Grade 1
- Code classification: 4-4-5
- Hydrostatic design stress: 1250 psi
• Pressure Ratings of Pipes and Fittings
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Pressure
Solids - Densities
Densities of selected solids.
Water Hammer
Rapidly closing or opening valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammer.
