1) For cast iron stacks, the base of each stack must be supported
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Pressure ratings of ABS 1208, ABS 1210, ABS 1316 and ABS 2112.
Nominal pipe size, outside diameter, thickness and weight.
Dimensions of cast iron soil pipes.
Cleanouts provides access to the sewer for rodding.
Recommended drain trap sizes for different types of fixtures
Minimum pitch of horizontal drainage pipes.
Maximum distance between PolyPropylene pipes supports.
Maximum distance between pressfit pipe supports.
Calculate expected volume flow load in sanitary drainage systems.
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
