Cleanouts in Draining Systems
Drain cleanouts provide access to the sewer for cleaning without disassembling appliances like toilets or pipes.
Sewers in modern plastic materials, properly designed and installed, should require minimal or no maintenance.
  • cleanouts are required at base of stacks and at each horizontal change of 45o or more
  • if more than 1 change in direction in a run of a pipe, only 1 cleanout every 40 ft (12 m) is required
  • cleanouts should be installed every 75 - 100 ft (25 - 30 m)
Cleanouts size and clearance distance in front of the cleanout can be taken from the table below:
Pipe Size
(in)
Cleanout Size
(in)
Clearance
(in)
1 /1/2 1 1/2 12
2 1 1/2 12
2 1/2 2 1/2 12
3 2 1/2 18
4 or larger 3 1/2 18
  • 1 inch = 25.4 mm
Dimensions
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems.
Drain Pipes and Vent Stacks
Drain pipes and vent stack sizing.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Horizontal Drainage Pipe - Required Slopes
Minimum pitch of horizontal drainage pipes.
Horizontal Storm Drain Piping
Capacities of horizontal storm drain piping systems.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Septic Systems
Septic systems handles waste from drain systems.
Waste Water Piping - Flow Capacities vs. Dimensions
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
