Note! - based on clean pipes. The friction coefficient may vary with the pipe material.
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Dimensions of cast iron soil pipes.
Cleanouts provides access to the sewer for rodding.
Drain pipes and vent stack sizing.
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Recommended drain trap sizes for different types of fixtures
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
Relative capacity between larger and smaller pipes.
Calculate expected volume flow load in sanitary drainage systems.
Septic systems handles waste from drain systems.
Viscosity of sewage sludge vs. content of solids.
