NPS
(inches)
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
Maximum space between supports aand clips for copper tubes.
Recommended distance between ductwork support hangers.
Dimensions of welded stainless steel tubes according EN 10312.
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Support spacing for reinforced Epoxy fiberglass pipes.
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
Maximum distance between PolyPropylene pipes supports.
Distance between PVC pipe supports.
Maximum distance between PVDF pipe supports.
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Recommended max. distance between steel pipe supports.
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Weight rating of threaded hanger rods.
Proof load capacities of metric threaded steel rods.
