NPS (inches) | Maximum Support Spacing (feet) | ||
Operating Temperature (oF) | |||
80 | 100 | 1401) | |
1/2 | 4 1/2 | 4 1/2 | 2 1/2 |
3/4 | 4 1/2 | 4 1/2 | 3 |
1 | 5 | 4 1/2 | 3 |
1 1/2 | 5 1/2 | 5 | 3 |
2 | 5 1/2 | 5 | 3 |
1) For temperatures above 140 oF continuous support of the pipes is needed.
PVDF is recognized by its high mechanical strength and excellent chemical resistance even at higher temperatures.
Maximum space between supports aand clips for copper tubes.
Sizing of copper wire and transformers for three phase 230 & 460V electrical motors.
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
Maximum distance between PolyPropylene pipes supports.
Maximum distance between pressfit pipe supports.
Recommended max. distance between steel pipe supports.
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
