Efficiency
Efficiency is the measure of "usefulness" of an operation, process or machine - and can be expressed on the generic form
μ = Wo / Wi (1)
μ = efficiency
Wo = output from the operation - can be work, power, produced products ... (W, ...)
Wi = input to the operation - can work, power, input products ... (W, ...)
Efficiency can be expressed as a percentage or as a per-unit decimal fraction of 1.
Example - Efficiency of an Electric Motor
The input power to an electric motor is 2000 W. The output power to the shaft is 1800 W. The efficiency of the motor can be calculated as
μ = (1800 W) / (2000 W)
= 0.9
= 90%
Example - Efficiency of a Wind Mill
The teoretical energy potential for a wind mill is 300 kWh at given conditions. The power produced is 70 kWh. The efficiency of the wind mill can be calculated as
μ = (70 kWh) / (300 kWh)
= 0.23
= 23%
• Basics
Air Conditioner Efficiency
The ratio between heat removed and power (watt) used - EER and SEER.
Boiler - Efficiency
Combustion gross and net calorific value.
Carnot Cycle Efficiency
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Cooling and Heating - Performance and Efficiency Terminology
Performance and efficiency terminology related to heat pumps and air condition systems.
Cooling Tower Efficiency
Maximum cooling tower efficiency is limited by the cooling air wet-bulb temperature.
Efficiency in Pumps or Fans
The overall pump and fan efficiency is the ratio power gained by the fluid to the shaft power supplied.
Electric Motors - Efficiency
Heat Recovery Efficiency
