Energy Transfer Equation
The energy transfered with a substance can be expressed as
Q = m cp dt (1)
Q = quantity of energy transferred (kJ, Btu)
m = mass of substance (kg, lb)
cp = specific heat of the substance (kJ/kgoC, kJ/kgoK, Btu/lboF)
dt = temperature difference (rise or fall) in the substance (oC, K, oF)
Example - Energy Transfer with Water
2 kg of water is heated from 20 oC to 60 oC. The specific heat of water is 4.2 kJ/kgoC. The heat transfered can be calculated as
Q = (2 kg) (4.2 kJ/kgoC) ((60 oC) - (20 oC))
= 336 kJ
= (336 kWs) (1/3600 h/s)
= 0.093 kWh
• Thermodynamics
1st Law of Thermodynamics
Carnot Cycle Efficiency
Conductive Heat Transfer
Energy
Energy is the capacity to do work.
Energy Accumulated in Heated Water - kWh
Energy Conversion Factors
Convert between energy units
Heat Recovery Efficiency
Heat, Work and Energy
Heat vs. work vs. energy.
Heating Up Applications - Energy Required and Heat Transfer Rates
Energy required to heat up a substance.
Radiation Heat Transfer
Understanding Convective Heat Transfer: Coefficients, Formulas & Examples
