Efficiency
A general definition of efficiency is the ratio between the useful energy or power output and the energy or power input - and can be expressed as
μ = Eo / Ei (1)
μ = efficiency
Eo = useful energy or power output(Joules, W)
Ei = energy input or power (Joules, W)
• Thermodynamics
2nd Law of Thermodynamics
Entropy and disorder.
Air Conditioner Efficiency
The ratio between heat removed and power (watt) used - EER and SEER.
Boiler - Efficiency
Combustion gross and net calorific value.
Carnot Efficiency
Cooling and Heating - Performance and Efficiency Terminology
Performance and efficiency terminology related to heat pumps and air condition systems.
Cooling Load - Convert between kW/ton to COP or EER
Convert between cooling load units like kW/ton, COP and EER.
Electric Motors - Efficiency
Fans - Efficiency and Power Consumption
Power consumption and typical efficiencies of fans
Heat Pumps - Performance and Efficiency Ratings
Performance and efficiency rating of heat pumps.
Heat Recovery Efficiency
Power
Power Plants - Performance Efficiencies
Power plants heat rates, thermal efficiencies, capacity factors, load factors, economic efficiencies, operational efficiencies and energy efficiencies.
Wind Power
Power generation from wind.
