dp inWG = total pressure (in. W.G)
The actual power - brake horse power - a fan requires, because no fan is 100% efficient, can be expressed as
P BHP = q dp inWG / μ 6356 (2)
P BHP = Brake Horse Power (hp)
μ = fan efficiency
The affinity laws can be used to calculate resulting volume capacity, head or power consumption when speed or wheel diameters are changed.
Fan classification established by AMCA.
Power consumption and typical efficiencies of fans
The temperature and density of the air influences on the volume flow, pressure head and power consumption in a fan.
Characterizing of impeller types in pumps in a unique and coherent manner.
Axial and propeller fans, centrifugal (radial) fans, mixed flow fans and cross flow fans.
Centrifugal, axial and propeller fans and their capacity ranges.
