Fan Class
A fan working with static pressure 4.5 in W.G. and outlet velocity 3500 ft/min is within AMCA Fan Class II.
The affinity laws can be used to calculate resulting volume capacity, head or power consumption when speed or wheel diameters are changed.
AHP - Air Horse Power and BHP - Brake Horse Power.
How to modulate fans and their capacities.
Power consumption and typical efficiencies of fans
The temperature and density of the air influences on the volume flow, pressure head and power consumption in a fan.
The difference between pumps, compressors, blowers and fans.
Axial and propeller fans, centrifugal (radial) fans, mixed flow fans and cross flow fans.
