Protection against vertically falling drops of water e.g. condensation.
Note! NEMA standards meets or exceeds IEC standards. The conversion does not work in the opposite direction.
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Description of NEMA electrical enclosures types.
The eight - S1 - S8 - IEC duty cycles of operating electrical motors.
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
