Proper allowance in the pipe line is important to eliminate undue stress from thermal expansion.
Z-Shaped Expansion Compensator
Minimum leg length of Z-shaped pressfit piping temperature expansion loops:
U-Shaped Expansion Compensator
Minimum leg length of U-shaped pressfit piping temperature expansion loops:
  • 1 in (inch) = 25.4 mm = 0.0254 m = 0.08333 ft
Temperature Expansion
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Pressfit Pipes - Pressure Loss vs. Water Flow Diagram
Water flow pressure loss diagram.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
Pressfit Piping - Dimensions
Dimension of pressfit pipes.
Pressfit Piping - Friction Loss vs. Water Flow
Water flow friction loss in pressfit piping.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
