Piping Materials - Temperature Heat Expansion and Cooling Contraction
Temperature expansion of pipes or tubes with some commonly used materials:
For full table with wrought iron, stainless steel, copper, brass and aluminum - rotate the screen!
Saturated Steam Pressure1) (psi) | Temperature (oF) | Temperature Expansion of Pipes (in/100 ft) | ||||||||
Cast Iron | Carbon and carbon Molybdenum | Wrought Iron | 4-6% Cr. Alloy Steel | 12% Cr. Stainless Steel | 18 Cr. -8Ni Stainless Steel | Copper | Brass | Aluminum 2-S | ||
-200 | -1.058 | -1.282 | -1.289 | -1.250 | -1.170 | -2.030 | -1.955 | -2.065 | -2.69 | |
-180 | -0.982 | -1.176 | -1.183 | -1.150 | -1.070 | -1.850 | -1.782 | -1.890 | -2.44 | |
-160 | -0.891 | -1.066 | -1.073 | -1.030 | -0.970 | -1.670 | -1.612 | -1.705 | -2.18 | |
-140 | -0.797 | -0.948 | -0.955 | -0.970 | -0.870 | -1.480 | -1.428 | -1.508 | -1.93 | |
-120 | -0.697 | -0.826 | -0.833 | -0.800 | -0.750 | -1.300 | -1.235 | -1.308 | -1.67 | |
-100 | -0.593 | -0.698 | -0.705 | -0.700 | -0.630 | -1.100 | -1.040 | -1.098 | -1.40 | |
-80 | -0.481 | -0.563 | -0.570 | -0.550 | -0.520 | -0.880 | -0.835 | -0.888 | -1.12 | |
-60 | -0.368 | -0.428 | -0.435 | -0.430 | -0.400 | -0.670 | -0.630 | -0.673 | -0.85 | |
-40 | -0.248 | -0.288 | -0.295 | -0.290 | -0.270 | -0.450 | -0.421 | -0.452 | -0.58 | |
-20 | -0.127 | -0.145 | -0.152 | -0.145 | -0.130 | -0.225 | -0.210 | -0.227 | -0.28 | |
0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | |
20 | 0.128 | 0.148 | 0.180 | 0.140 | 0.140 | 0.223 | 0.238 | 0.233 | 0.32 | |
32 | 0.209 | 0.230 | 0.280 | 0.234 | 0.234 | 0.356 | 0.366 | 0.373 | 0.50 | |
29.39 | 40 | 0.270 | 0.300 | 0.350 | 0.280 | 0.280 | 0.446 | 0.451 | 0.466 | 0.63 |
60 | 0.410 | 0.448 | 0.540 | 0.430 | 0.430 | 0.669 | 0.684 | 0.690 | 0.93 | |
28.89 | 80 | 0.550 | 0.580 | 0.710 | 0.600 | 0.580 | 0.892 | 0.896 | 0.920 | 1.24 |
27.99 | 100 | 0.680 | 0.753 | 0.887 | 0.650 | 0.690 | 1.115 | 1.134 | 1.150 | 1.53 |
26.48 | 120 | 0.830 | 0.910 | 1.058 | 0.800 | 0.820 | 1.338 | 1.366 | 1.390 | 1.84 |
24.04 | 140 | 0.970 | 1.064 | 1.240 | 0.950 | 0.960 | 1.545 | 1.590 | 1.625 | 2.15 |
20.27 | 160 | 1.110 | 1.200 | 1.420 | 1.100 | 1.090 | 1.784 | 1.804 | 1.865 | 2.46 |
14.63 | 180 | 1.240 | 1.360 | 1.580 | 1.250 | 1.230 | 2.000 | 2.051 | 2.100 | 2.77 |
6.45 | 200 | 1.390 | 1.520 | 1.750 | 1.400 | 1.380 | 2.230 | 2.296 | 2.340 | 3.08 |
0 | 212 | 1.480 | 1.610 | 1.870 | 1.500 | 1.460 | 2.361 | 2.428 | 2.467 | 3.28 |
2.5 | 220 | 1.530 | 1.680 | 1.940 | 1.550 | 1.510 | 2.460 | 2.516 | 2.580 | 3.41 |
10.3 | 240 | 1.670 | 1.840 | 2.120 | 1.720 | 1.650 | 2.680 | 2.756 | 2.830 | 3.73 |
20.7 | 260 | 1.820 | 2.020 | 2.300 | 1.880 | 1.790 | 2.920 | 2.985 | 3.070 | 4.07 |
34.5 | 280 | 1.970 | 2.180 | 2.470 | 2.050 | 1.930 | 3.150 | 3.218 | 3.315 | 4.40 |
52.3 | 300 | 2.130 | 2.350 | 2.670 | 2.200 | 2.080 | 3.390 | 3.461 | 3.565 | 4.74 |
74.9 | 320 | 2.268 | 2.530 | 2.850 | 2.370 | 2.220 | 3.615 | 3.696 | 3.820 | 5.10 |
103.3 | 340 | 2.430 | 2.700 | 3.040 | 2.530 | 2.360 | 3.840 | 3.941 | 4.065 | 5.43 |
138.3 | 360 | 2.590 | 2.880 | 3.230 | 2.700 | 2.510 | 4.100 | 4.176 | 4.350 | 5.78 |
180.9 | 380 | 2.750 | 3.060 | 3.425 | 2.860 | 2.670 | 4.346 | 4.424 | 4.610 | 6.13 |
232.4 | 400 | 2.910 | 3.230 | 3.620 | 3.010 | 2.820 | 4.580 | 4.666 | 4.870 | 6.47 |
293.7 | 420 | 3.090 | 3.421 | 3.820 | 3.180 | 2.980 | 4.800 | 4.914 | 5.150 | 6.84 |
366.1 | 440 | 3.250 | 3.595 | 4.020 | 3.350 | 3.130 | 5.050 | 5.154 | 5.400 | 7.19 |
451.3 | 460 | 3.410 | 3.784 | 4.200 | 3.530 | 3.290 | 5.300 | 5.408 | 5.680 | 7.55 |
550.3 | 480 | 3.570 | 3.955 | 4.400 | 3.700 | 3.450 | 5.540 | 5.651 | 5.950 | 7.90 |
664.3 | 500 | 3.730 | 4.151 | 4.600 | 3.860 | 3.600 | 5.800 | 5.906 | 6.220 | 8.25 |
795.3 | 520 | 3.900 | 4.342 | 4.810 | 4.040 | 3.760 | 6.050 | 6.148 | 6.500 | 8.61 |
945.3 | 540 | 4.080 | 4.525 | 5.020 | 4.200 | 3.930 | 6.280 | 6.410 | 6.780 | 8.98 |
1) Vacuum in degree below 211 oF, psi gauge above 211 oF
- T (oC) = 5/9 (T (oF) - 32)
- 1 in (inch) = 25.4 mm
- 1 ft (foot) = 0.3048 m
• Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
• Temperature Expansion
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
