Pressfit Piping - Dimensions
Dimensions of pressfit Schedule 5 Carbon Steel Pipe or Type 304/304L and Type 316/316L Stainless steel pipes:
For full table with Weight - rotate the screen!
Nominal Diameter | Actual Outside Diameter | Inside Diameter | Wall Thickness | Weight | |||||
(inches) | (mm) | (inches) | (mm) | (inches) | (mm) | (inches) | (mm) | (lbs/ft) | (kg/m) |
1/2 | 15 | 0.840 | 21.3 | 0.710 | 18.0 | 0.065 | 1.7 | 0.6 | 0.9 |
3/4 | 20 | 1.050 | 26.9 | 0.920 | 23.4 | 0.065 | 1.7 | 0.7 | 1.1 |
1 | 25 | 1.315 | 33.7 | 1.185 | 30.1 | 0.065 | 1.7 | 0.9 | 1.3 |
1 1/4 | 32 | 1.660 | 42.4 | 1.530 | 38.9 | 0.065 | 1.7 | 1.1 | 1.6 |
1 1/2 | 40 | 1.900 | 48.3 | 1.770 | 45.0 | 0.065 | 1.7 | 1.3 | 1.9 |
2 | 50 | 2.375 | 60.3 | 2.2245 | 57.0 | 0.065 | 1.7 | 1.6 | 2.4 |
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Hot Water Heating System Online Design Application
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pressfit Pipes - Pressure Loss vs. Water Flow Diagram
Water flow pressure loss diagram.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
Pressfit Piping - Friction Loss vs. Water Flow
Water flow friction loss in pressfit piping.
