Malleability vs. Brittlenes vs. Ductility
Malleability
- whereby a material can be plastic deformed and shaped when cold
A malleable material can be plastic shaped with hammering or rolling without fracture.
Typical malleable materials:
- mild steel, gold, lead
Brittleness
- whereby a material will fracture without appreciable prior plastic deformation
Brittleness is lack of ductility and for a brittle material there is no plastic deformation. The elastic stage is followed by immediate fracture.
Typical brittle materials:
- glass, concrete, ceramics, stone, gray cast iron
Ductility
- whereby a material can be plastic deformed by elongation without fracture
Ductile materials can typically be plastic elongated with more than 15% before they fracture.
Typical ductile materials:
- copper, mild steel, thermoplastics
Specification of Ductility
Ductility can be specified as percent elongation before rupture as
DL = 100% (Lf - L0) / L0 (1)
DL = ductility related to elongation (%)
Lf = final length of specimen at fracture (m, mm, in...)
L0 = original length of specimen (m, mm, in...)
Alternatively ductility can be specified as percent reduction of area as
DA = 100% (A0 - Af) / A0 (2)
DA = ductility related to reduction of area (%)
Af = final area of specimen at fracture (m, mm, in...)
A0 = original area of specimen (m, mm, in...)
Brinell Hardness Number - BHN
The Brinell hardness test of metals and alloys.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Mineral Hardness - Mohs Scale
The Mohs qualitative ordinal scale characterizes the scratch resistance of various minerals.
Minerals - Densities
Densities of minerals.
Poisson's Ratio
When a material is stretched in one direction it tends to get thinner in the other two directions.
Poisson's Ratios Metals
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
