Stones - Weight and Strength
StoneCrushing Weight (lbf/in2)Shearing Strength (lbf/in2)Strength
(lbf)
Sandstone 150 8000 1500
Granite 170 15000 2000
Limestone 170 6000 1000
Marble 170 10000 1400
Slate 175 15000
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2)
  • 1 lbf (Pound force) = 4.45 N = 0.454 kp
Material Properties
Miscellaneous
Angles of Repose
Tipping or dumping angles for common materials like ashes, sand, earth, shingles and more.
Concrete Mixtures
Cement, sand and gravel mixtures.
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
Minerals - Densities
Densities of minerals.
Soil and Rock - Bulk Factors
Solids - Densities
Densities of selected solids.
Solids - Specific Heats
Stockpile Volumes
Volume of natural stockpiles - cubic feet, yard, metre and decimetre.
Stone Masonry - Strength
Typical strength of stone masonry constructions.
Storing Thermal Heat
Energy stored as sensible heat in different types of materials.
