Stone Masonry - Strength
Typical strength of stone masonry:
MaterialCrushing
(N/mm2)
Tension
(N/mm2)
Shear
(N/mm2)
Basalt 8.5 8.6 4.3
Granite 96.6 3.2 5.4
Limestone 53.7 2.7 4.3
Marble 64.4 3.2 5.4
Sandstone 53.7 1.1 3.2
Slate 85.8 1.1 3.2
  • 1 N/mm2 = 145 psi
Material Properties
Concrete Mixtures
Cement, sand and gravel mixtures.
Minerals - Densities
Densities of minerals.
Solids - Densities
Densities of selected solids.
Solids - Specific Heats
Typical strength of stone masonry constructions.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
