Concrete Mixtures
Commonly used cement, sand and gravel mixtures:
Concrete Mixtures
ContructionMaterials Volume RatioMaterials Required
CementSandGravelCement
(sacks)
Sand
(cubic yards)
Gravel
(cubic yards)
Normal static loads, no rebar, not exposed 1 3 6 4.2 0.5 0.95
Foundations and walls, normal static loads, exposed 1 2.5 5 5.6 0.45 0.9
Basement walls 1 2.5 4 5.6 0.5 0.8
Basement walls, waterproof 1 2.5 3.5 5.9 0.55 0.8
Floors, light duty, driveways, sidewalks 1 2.5 3
Reinforced roads, walls, exposed 1 2 4
High strength, floors, columns 1 1 2
  • 1 cubic yards = 0.7646 m3 = 27 ft3
Material Properties
ACI - American Concrete Institute
American Concrete Institute.
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Building Foundations - Loads
Typical loads on building foundations.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Mixtures
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Gravel - Cover Area
Gravel aggregate covering area.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Minerals - Densities
Densities of minerals.
Minerals and other Materials - Specific Gravities
Specific gravities for minerals and other materials.
Mortar Types
ASTM mortar types.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Stone Masonry - Strength
Typical strength of stone masonry constructions.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
