Building Foundations - Loads
Typical maximum loads on building foundations:
  • Concrete frame, masonry clad : 20 - 25 kN/m2
  • Steel frame, masonry clad : 15 - 20 kN/m2
  • Precast concrete floor slabs, masonry walls : 15 - 20 kN/m2
  • Timber frame, masonry clad : 10 - 15 kN/m2
  • Steel frame, steel clad : 5 - 10 kN/m2
Miscellaneous
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Floor Joist Capacities
Floors - Live Loads
Typical Floor Loads
Uniformly and concentrated floor loads
