Floor Joist Capacities
Floor Joist Capacities - max working load 3.0 kN/m2
Floor joist capacities for timber grade C 18, C 24 and C 30 - joist center space ranging 300 to 600 mm - are indicated in the diagram below.
Floor Joist Capacity - max working load 2.0 kN/m2
The strength classes C 16, C 24 and C 30 referes to Eurocode 5 and BS 5268.
Beams and Columns
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Building Foundations - Loads
Typical loads on building foundations.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Floor Vibrations
Human activities like walking, running and dancing - and operating machines - can introduce floor vibrations due to resonance.
Floors - Live Loads
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Low-Frequency Vibrations Effects on Building Constructions
Effects of low-frequency vibrations on building constructions.
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Typical Floor Loads
Uniformly and concentrated floor loads
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
Wood Beams - Strength of Material
Wood Headers - Max. Supported Weight
