Floors - Live Loads
Minimum uniformly distributed live loads:
Floors - Live Loads
UseLive Load
(psf)(N/m2)
Attics, no storage with roof slope no steeper than 3 in 12 10 479
Attics, limited storage 20 958
Balconies 60 2873
Decks 40 1915
Fire escapes 40 1915
Garages, passenger cars 50 2394
Sleeping rooms 30 1436
Stairs 40 1915
  • 1 psf (lbf/ft2) = 47.88 N/m2 (Pa)
How to Calculate Load in N?
If you have the mass in kg - the load in N can be calculated as
F = m g                 (1)
F = load (N)
m = mass (kg)
g = gravitational acceleration (9.81 m/s2)
Example - Calculate the Load from a 800 kg Pallet
The load from a pallet with mass 800 kg can be calculated as
F = (800 kg) (9.81 m/s2
  = 7848 N
  = 7.8 kN
Beams and Columns
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Beams Natural Vibration Frequency
Estimate structures natural vibration frequency.
Building Foundations - Loads
Typical loads on building foundations.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Floor Joist Capacities
HE-A Steel Beams
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Low-Frequency Vibrations Effects on Building Constructions
Effects of low-frequency vibrations on building constructions.
Mass vs. Weight
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Typical Floor Loads
Uniformly and concentrated floor loads
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
Wood Beams - Strength of Material
Wood Headers - Max. Supported Weight
