HE-A Steel Beams
Properties of HE-A steel beams according DIN 1025 and Euronorm 53-62
For full table with Static Parameters - Moment of Inertia and Elastic Section Modulus - rotate the screen!
HEA | Dimensions | Static Parameters | |||||||
Moment of Inertia | Elastic Section Modulus | ||||||||
Depth h (mm) | Width w (mm) | Web Thickness s (mm) | Sectional Area (cm2) | Weight (kg/m) | Ix (cm4) | Iy (cm4) | Wx (cm3) | Wy (cm3) | |
100A | 96 | 100 | 5 | 21.2 | 16.7 | 349 | 134 | 72.8 | 26.8 |
120A | 114 | 120 | 5 | 25.3 | 19.9 | 606 | 231 | 106 | 38.5 |
140A | 133 | 140 | 5.5 | 31.4 | 24.7 | 1030 | 389 | 155 | 55.6 |
160A | 152 | 160 | 6 | 38.8 | 30.4 | 1670 | 616 | 220 | 76.9 |
180A | 171 | 180 | 6 | 45.3 | 35.5 | 2410 | 925 | 294 | 103 |
200A | 190 | 200 | 6.5 | 53.8 | 42.3 | 3690 | 1340 | 389 | 134 |
220A | 210 | 220 | 7 | 64.3 | 50.5 | 5410 | 1950 | 515 | 178 |
240A | 230 | 240 | 7.5 | 76.8 | 60.3 | 7760 | 2770 | 675 | 231 |
260A | 250 | 260 | 7.5 | 86.8 | 68.2 | 10450 | 3670 | 836 | 282 |
280A | 270 | 280 | 8 | 97.3 | 76.4 | 13670 | 4760 | 1010 | 340 |
300A | 290 | 300 | 8.5 | 112 | 88.3 | 18260 | 6310 | 1260 | 421 |
320A | 310 | 300 | 9 | 124 | 97.6 | 22930 | 6990 | 1480 | 466 |
340A | 330 | 300 | 9.5 | 133 | 105 | 27690 | 7440 | 1680 | 499 |
- 1 cm4 = 104 mm4 = 10-8 m4 = 0.024 in4
- 1 cm3 = 103 mm3 = 10-6 m3 = 0.061 in3
- 1 cm2 = 102 mm2 = 10-4 m2 = 0.16 in2
- 1 kg/m = 0.67 lb/ft
I-shaped cross-section beams:
- Britain : Universal Beams (UB) and Universal Columns (UC)
- Europe : IPE. HE. HL. HD and other sections
- US : Wide Flange (WF) and H sections
• Beams and Columns
• Mechanics
Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units.
American Standard Beams - S Beam
American Standard Steel Channels: Weight, Dimensions & Properties
American Wide Flange Steel Beams (W-Beams) - Dimensions and Properties in Imperial Units
Dimensions, weight, section properties, and essential data of American wide flange steel beams (W-beams) according to the ASTM A6 standard.
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Continuous Beams - Moment and Reaction Support Forces
Moments and reaction support forces with distributed or point loads.
Euler Column Buckling: Formula, Theory & Calculator
Calculate buckling of columns.
Floors - Live Loads
HE-A Steel Beams
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Normal Flange I-Beams
Square Hollow Structural Sections (HSS) – Sizes, Strength & Specifications
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns.
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
Wood Beams - Strength of Material
