= 0.38 kN
The reaction force in the center support can be calculated as
Rcenter = (1.250) (1000 N/m)
= 1250 N
= 1.25 kN
The beam moments at the middle of spans with span length 1m can be calculated as
Mend = (0.070) (1000 N/m) (1 m)2
= 70 Nm
The beam moment at the center support can be calculated as
Mcenter = (0.125) (1000 N/m) (1 m)2
= 125 Nm
For a continuous beam with 3, 4 or 5 supports and point loads the reaction support forces can be calculated as
R = cr F (3)
cr = reaction support force coefficient from the figure above
F = point load (N, lbf)
The moments can be calculated as
M = cm F L (4)
cm = moment coefficient from the figure above
The reaction forces in the end supports for a continuous beam with 3 supports and 2 point loads 1000 N can be calculated as
Rend = (0.313) (1000 N)
= 313 N
= 0.31 kN
Rcenter = (1.375) (1000 N)
= 1375 N
= 1.4 kN
The beam moments at point loads with span length 1m can be calculated as
Mend = (0.156) (1000 N) (1 m)
= 156 Nm
Mcenter = (0.188) (1000 N) (1 m)
= 188 Nm
Calculate the acting forces and moments when elevating drawbridges or beams.
Support reactions and bending moments.
