I-shaped cross-section beams:
Dimensions and static properties of aluminum I-beams - Imperial units.
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Moments and reaction support forces with distributed or point loads.
Properties of HE-M profile steel beams.
Allowable concentric loads for steel pipe columns.
