American Standard Beams - S Beam
Properties in imperial units of American Standard Beams according ASTM A6 are indicated below.
For full table with Static Parameters - Moment of Inertia and Elastic Section Modulus - rotate the screen!
American Standard S Beams - Properties
DesignationDimensionsStatic Parameters
Moment of InertiaElastic Section Modulus
Imperial
(in x lb/ft)
Depth
- h -
(in)
Width
- w -
(in)
Web Thickness
- s -
(in)
Sectional Area
(in2)
Weight
(lbf/ft)
Ix
(in4)
Iy
(in4)
Sx
(in3)
Sy
(in3)
S 24 x 121 24.5 8.050 0.800 35.6 121 3160 83.3 258 20.7
S 24×106 24.5 7.780 0.620 31.2 106 2940 77.1 240 19.6
S 24×100 24 7.425 0.745 29.3 100 2390 47.7 199 13.2
S 24 x 90 24 7.125 0.625 26.5 90 2250 44.9 187 12.6
S 24 x 80 24 7.000 0.500 23.5 80 2100 42.2 175 12.1
S 20 x 96 20.3 7.200 0.800 28.2 96 1670 50.2 165 13.9
S 20 x 86 20.3 7.060 0.660 25.3 86 1580 46.8 155 13.3
S 20 x 75 20 6.385 0.635 22.0 75 1280 29.8 128 9.32
S 20 x 66 20 6.255 0.505 19.4 66 1190 27.7 119 8.85
S 18 x 70 18 6.251 0.711 20.6 70 926 24.1 103 7.72
S 18 x 54.7 18 6.001 0.461 16.1 54.7 804 20.8 89.4 6.94
S 15 x 50 15 5.640 0.550 14.7 50 486 15.7 64.8 5.57
S 15 x 42.9 15 5.501 0.411 12.6 42.9 447 14.4 59.6 5.23
S 12 x 50 12 5.477 0.687 14.7 50 305 15.7 50.8 5.74
S 12 x 40.8 12 5.252 0.462 12.0 40.8 272 13.6 45.4 5.16
S 12 x 35 12 5.078 0.428 10.3 35 229 9.87 38.2 3.89
S 12 x 31.8 12 5.000 0.350 9.35 31.8 218 9.36 36.4 3.74
S 10 x 35 10 4.944 0.594 10.3 35 147 8.36 29.4 3.38
S 10 x 25.4 10 4.661 0.311 7.46 25.4 124 6.79 24.7 2.91
S 8 x 23 8 4.171 0.441 6.77 23 64.9 4.31 16.2 2.07
S 8 x 18.4 8 4.001 0.271 5.41 18.4 57.6 3.73 14.4 1.86
S 7 x 20 7 3.860 0.450 5.88 20 42.4 3.17 12.1 1.64
S 7 x 15.3 7 3.662 0.252 4.5 15.3 36.7 2.64 10.5 1.44
S 6 x 17.25 6 3.565 0.465 5.07 17.25 26.3 2.31 8.77 1.30
S 6 x 12.5 6 3.332 0.232 3.67 12.5 22.1 1.82 7.37 1.09
S 5 x 14.75 5 3.284 0.494 4.34 14.75 15.2 1.67 6.09 1.01
S 5×10 5 3.004 0.214 2.94 10 12.3 1.22 4.92 0.81
S 4 x 9.5 4 2.796 0.326 2.79 9.5 6.79 0.903 3.39 0.65
S 4 x 7.7 4 2.663 0.193 2.26 7.7 6.08 0.764 3.04 0.57
S 3 x 7.5 3 2.509 0.349 2.21 7.5 2.93 0.586 1.95 0.47
S 3 x 5.7 3 2.330 0.170 1.67 5.7 2.52 0.455 1.68 0.39
  • 1 in3 = 1.64×104 mm3= 16.4 cm3
  • 1 in4 = 4.16×105 mm4 = 41.6 cm4
  • I = moment of inertia
  • W = section modulus
The standard method for specifying the dimension of a American Standard Beam is for example W 20 x 86, which is 20 inches deep with a weight of 86 lb/ft.
I-shaped cross-section beams:
  • Britain : Universal Beams (UB) and Universal Columns (UC)
  • Europe : IPE. HE. HL. HD and other sections
  • US : Wide Flange (WF) and H sections
Beams and Columns
Mechanics
American Standard Steel Channels: Weight, Dimensions & Properties
American Wide Flange Steel Beams (W-Beams) - Dimensions and Properties in Imperial Units
Dimensions, weight, section properties, and essential data of American wide flange steel beams (W-beams) according to the ASTM A6 standard.
American Wide Flange Steel Beams: Dimensions and Properties (ASTM A6 in Metric)
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia with Definitions, Formulas & Calculator
Explore the area moment of inertia (second moment of area) with detailed formulas, calculation tools, and reference tables for common shapes. Essential for structural and mechanical engineering applications.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Normal Flange I-Beams
Square Hollow Structural Sections (HSS) – Sizes, Strength & Specifications
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
