Steel Angles - Unequal Legs
Properties in imperial units of steel angles with unequal legs are indicated below.
For full table with Static Parameters Moment of Inertia and Section Modulus - rotate the screen!
Steel Angles - Unequal Legs - Dimensions and Static Parameters
Size
(mm x mm)
DimensionsStatic Parameters
Moment of InertiaSection Modulus
Depth
- h -
(mm)
With
- w -
(mm)
Thickness
- s -
(mm)
Sectional Area
(cm2)
Weight
(kg/m)
- Ix -
(cm4)
- Iy -
(cm4)
- Sx -
(cm3)
- Sy -
(cm3)
50 x 40 50 40 6 5.1 3.9 12.1 6.5 3.54 2.35
50 40 5 4.3 3.3 10.3 5.6 3.00 1.99
60 x 30 60 30 6 5.1 4.0 18.2 3.0 4.78 1.32
60 30 5 4.3 3.3 15.6 2.6 4.04 1.12
65 x 50 65 50 8 8.6 8.6 34.8 17.7 7.93 4.9
65 50 6 6.6 6.6 27.2 14.0 6.10 3.8
65 50 5 5.5 5.5 23.2 11.9 5.14 3.2
75 x 50 75 50 10 11.6 11.6 64 22.2 12.8 6.1
75 50 8 9.4 9.4 52 18.4 10.4 4.9
75 50 6 7.2 7.2 41 14.4 8.0 3.8
80 x 60 80 60 8 10.6 10.6 66 31.8 12.2 7.2
80 60 7 9.4 9.4 59 28.4 10.7 6.3
80 60 6 8.1 8.1 51 24.8 9.3 5.5
100 x 65 100 65 10 15.6 15.6 154 51 23.2 10.5
100 65 8 12.7 12.7 127 42 18.9 8.5
100 65 7 11.2 11.2 113 38 16.6 7.5
100 x 75 100 75 12 19.7 19.7 189 90 28.0 16.5
100 75 10 16.6 16.6 162 78 23.8 14.0
100 75 8 13.5 13.5 133 64 19.3 11.4
125 x 75 125 75 12 22.7 22.7 354 96 43.2 16.9
125 75 10 19.1 19.1 302 82 36.5 14.3
125 75 8 15.5 15.5 247 68 29.6 11.6
150 x 75 150 75 15 31.6 31.6 713 120 75 21.0
150 75 12 25.7 25.7 589 100 61 17.2
150 75 10 21.6 21.6 501 86 52 14.6
150 x 90 150 90 15 33.9 33.9 761 205 78 30.4
150 90 12 27.5 27.5 927 171 63 24.8
150 90 10 23.2 23.2 533 146 53 21.0
200 x 100 200 100 15 43 43 1758 299 137 38.4
200 100 12 34.8 34.8 1440 247 111 31.3
200 100 10 29.2 29.2 1220 210 93 26.3
200 x 150 200 150 18 60.0 60 2376 1146 174 103
200 150 15 50.5 50.5 2022 976 147 87
200 150 12 40.8 40.8 1652 803 119 71
  • 1 in = 25.4 mm
  • 1 cm4 = 10-8 m = 104 mm
  • 1 in4 = 4.16x105 mm4 = 41.6 cm4
  • 1 cm3 = 10-6 m3 = 103 mm3
Beams and Columns
American Standard Beams - S Beam
American Standard Steel C Channels
American Wide Flange Beams
Area Moment of Inertia - Typical Cross Sections I
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Cantilever Beams - Moments and Deflections
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
HE-A Steel Beams
Miter Saw - Calculate Sawing Angle
Calculate miter saw protractor angles for skirting and decorative mouldings work.
Modulus of Rigidity
Square Hollow Structural Sections - HSS
Steel Angles - Equal Legs
W-Beams - American Wide Flange Beams
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
