Weight of Beams - Stress and Strain
Axial Force
The axial force acting in a cross sectional area in distance x in a vertical beam due to it's own weight - can be calculated as
Fx = γ  A (L - x)                                    (1)
Fx = axial force in distance x (N)
y = specific weight - unit volume weight (N/m3)
A = cross-sectional area (m2)
L = length of beam (m)
x = distance (m)
The specific weight can be expressed as
y = ρ g                                          (2)
ρ = density of beam (kg/m3)
(1) can with (2) be modified to
Fx = ρ g  A (L - x)                            (2b)
Axial Stress
The axial stress at a distance x can be calculated as
σx = Fx / A
    = γ (L - x)
    =  ρ g (L - x)                              (3)
σx = axial stress (Pa, N/m2)
Note! - the cross-sectional area is irrelevant.
The axial stress at distance x = L
σx=L = γ (L - L)
    = ρ g (L - L)
    = 0                                    (3a)
The axial stress at distance x = 0
σx=0 = γ (L - 0)
    = ρ g (L - 0)
    = γ L
    = ρ g L                               (3b)
Axial Deformation
The axial deformation at distance x can be calculated as
dxx = y x (2 L - x) / (2 E)
      =   ρ g x (2 L - x) / (2 E)                           (4)
dx = deformation (m)
E = modulus of elasticity (N/m2)
The axial deformation at distance x = L
dxx=L = y L2 / (2 E)
         = ρ g L2 / (2 E)                                (4a)
The axial deformation at distance x = 0
dxx=0 = 0                                    (4b)
Example - Stress and Axial Deformation of a Vertical Steel Rod
A 45 m long steel rod with density 7280 kg/m3 and cross-sectional area 0.1 m2 is mounted as indicated in the figure above.
The maximum force acting in the rod at distance x = 0 m can be calculated with (1b)
Fx=0  = (7280 kg/m3) (9.81 m/s2) (0.1 m2) ((45 m) - (0 m))
   = 321376 N
   = 321 kN
The maximum axial stress in the rod at distance x = 0 m can be calculated (3b)
σx=0 = (7280 kg/m3) (9.81 m/s2) (45 m)
        = 3213756 N/m2 (Pa)
        = 3.2 MPa
The modulus of elasticity for the steel rod is 200 GPa (200 109 N/m2).  The axial deformation at distance x = 45 m can be calculated with (4a)
dxx=45 = (7280 kg/m3) (9.81 m/s2) (45 m)2 / (2 (200 109 N/m2))
       = 0.00036 m
       = 0.4 mm
Beams and Columns
Mechanics
American Standard Beams - S Beam
American Wide Flange Beams
Area Moment of Inertia - Typical Cross Sections I
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Cantilever Beams - Moments and Deflections
Euler's Column Formula
Calculate buckling of columns.
HE-A Steel Beams
Normal Flange I-Beams
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
W-Beams - American Wide Flange Beams
Wood Beams - Strength of Material
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
