Floor Vibrations
Human activities like walking, dancing or running may generate frequency acting forces in a construction.
The frequencies are in general in the range 1.0 to 3.0 Hz (1/s) - normally below the most common resonance frequencies for floor constructions.
Typical resonate frequencies in wooden beam floors are
  • Joist span 3 m : 12 Hz
  • Joist span 6 m : 9 Hz
  • Joist span 9 m : 7 Hz
  • Joist span 12 m : 6 Hz
  • Joist span 18 m : 5 Hz
Resonate frequencies in concrete floors on the ground depends on the materials in the ground below. Typical resonate frequencies ranges 10 - 100 Hz
  • Sand : 15 - 25 Hz
  • Clay, wet : 15 Hz
  • Clay, hard : 30 Hz
  • Gravel : 20 - 25 Hz
  • Limestone : 35 - 45 Hz
  • Solid rock : 40 - 50 Hz
Example - Running Cadence
The force frequency - f  - for a "everyday" runner with cadence 150 steps pr. minute can be calculated
f = (150 1/min) (1 / 60 min/s)
  = 2.5 (1/s, Hz)
The force frequency - f  - for a "elite" runner with cadence 200 steps pr. minute can be calculated
f = (200 1/min) (1 / 60 min/s)
  = 3.3 (1/s, Hz)
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Noise and Attenuation
Beams Natural Vibration Frequency
Estimate structures natural vibration frequency.
Floor Joist Capacities
Human Effects when Exposed to Low-Frequency Noise or Vibration
Physiological effects from low-frequency noise or vibrations.
Low-Frequency Vibrations Effects on Building Constructions
Effects of low-frequency vibrations on building constructions.
