Concrete - Calculating Cubic Volume
Concrete and mortar are normally delivered on a cubic volume basis. Cubic volume can be calculated as
V = l w h                                   (1)
V = cubic volume (yd3, ft3, m3)
l = length (yd, ft, m)
w = width (yd, ft, m)
h = height (yd, ft, m)
  • 1 ft3 = 0.02832 m3= 28.32 dm3 = 0.03704 yd3
  • 1 yd3 = 0.7646 m3 = 764.6 dm3 = 27 ft3
Miscellaneous
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footing
Estimating concrete continous footing.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
