Masonry Blocks - Dimensions
Typical Concrete Masonry Units - CMU - dimensions
Standard Blocks
| Nominal Size (in) | Actual Size (in) |
| 4 x 8 x 16 | 3-5/8 x 7-5/8 x 15-5/8 |
| 6 x 8 x 16 | 5-5/8 x 7-5/8 x 15-5/8 |
| 8 x 8 x 16 | 7-5/8 x 7-5/8 x 15-5/8 |
| 10 x 8 x 16 | 9-5/8 x 7-5/8 x 15-5/8 |
| 12 x 8 x 16 | 11-5/8 x 7-5/8 x 15-5/8 |
Half Blocks
| 4 x 8 x 8 | 3-5/8 x 7-5/8 x 7-5/8 |
| 6 x 8 x 8 | 5-5/8 x 7-5/8 x 7-5/8 |
| 8 x 8 x 8 | 7-5/8 x 7-5/8 x 7-5/8 |
| 12 x 8 x 8 | 11-5/8 x 7-5/8 x 7-5/8 |
- How many masonry units needed? Use this tool to calculate the number of concrete units needed.
Brick Densities
Densities of common types of bricks.
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footing
Estimating concrete continous footing.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
