Minerals and other Materials - Specific Gravities
MineralFormulaSpecific Gravity
Andesite 2.8
Barite 4.3
Basalt 2.9
Bauxite 2.4
Biotite complex 2.8 - 3.2
Calcite CaCO3 2.71
Cement clinker 3.1
Cement raw material 2.7
Chrome ore 4.1
Clay 2.2
Clay, calcined 2.3
Coal 1.6
Coke 1.5
Copper ore 3.0
Coral 2.7
Diorite 2.8
Dolomite CaMg(CO3) 2 2.85
Emery 3.5
Feldspar 2.6
Ferrochrome 6.7
Ferromanganese 5.9
Ferrosilicon 4.9
Flint 2.7
Fluorspar 3.0
Gabbro 2.8
Galena 5.4
Garnet 3.3
Glass 2.6
Gneiss 2.7
Gold ore 2.9
Granite 2.7
Graphite 1.8
Gravel 2.7
Gypsum CaSO4.2H2O 2.3
Gypsum rock 2.7
Hematite Fe2O3 5.2 - 5.3
Illite complex 2.6 - 2.86
Ilmenite 4.3
Iron ore 4.0
K Feldspar KAlSi3O8 2.54 - 2.57
Kaolinite Al2Si2O5(OH)4 2.61 - 2.66
Kyanite 3.2
Lead ore 3.4
Lead-zinc ore 3.4
Limestone 2.7
Limestone for cement 2.7
Magnesite, dead burned 5.2
Manganese ore 3.7
Mica 2.9
Molybdenum 2.7
Montmorillonite complex 2.74 - 2.78
Muscovite varies 2.76 - 3.0
Na Feldspar NaAlSi2O8 2.62 - 2.76
Nickel ore 3.3
Oil shale 1.8
Phosphate fertilizer 2.7
Phosphate rock 2.7
Potash ore 2.4
Potash salt 2.2
Pumice 2.0
Pyrite ore 3.5
Pyrrhotite ore 4.0
Quartz SiO2 2.65
Quartz 2.6
Quartzite 2.7
Rutile ore 2.8
Sandstone 2.7
Serpentine Mg3Si2O5(OH)4 2.5 - 2.6
Shale 2.6
Silica 2.7
Silica sand 2.7
Silicon carbide 2.7
Silver ore 2.7
Sinter 3.0
Slag 2.9
Slate 2.5
Sodium silicate 2.1
Spodumene ore 2.8
Syenite 2.7
Tile 2.6
Tin ore 3.9
Titanium ore 4.2
Trap rock 2.9
Uranium ore 2.7
Zinc ore 3.7
Material Properties
Concrete Mixtures
Cement, sand and gravel mixtures.
An introduction to density, specific weight and specific gravity.
Geological Time
Geological periods and time scale.
Metal Content in Minerals
Content of metals in minerals.
Mineral Hardness - Mohs Scale
The Mohs qualitative ordinal scale characterizes the scratch resistance of various minerals.
Minerals - Densities
Densities of minerals.
Solids - Densities
Densities of selected solids.
Solids - Specific Heats
Storing Thermal Heat in Materials
Energy stored as sensible heat in materials.
